查看: 883|回复: 10
【闲聊】《东亚文化论坛》原《汉字文化圈》挂了好长时间了!
发表于 2007-6-13 23:13:52 | 显示全部楼层 |阅读模式
 楼主| 发表于 2007-6-16 18:57:51 | 显示全部楼层
彻底的挂了!
  挂得彻彻底底的。
发表于 2007-6-16 19:27:57 | 显示全部楼层
似乎寄存在这里:
http://bbs.gophor.cn/
与福建之声在一起
 楼主| 发表于 2007-6-16 20:12:15 | 显示全部楼层
丑媳妇不敢见公婆?
发表于 2007-6-16 20:36:25 | 显示全部楼层
域名cjkvbbs.net的whois详细信息:
Whois Server Version 2.0
Domain names in the .com and .net domains can now be registered
with many different competing registrars. Go to http://www.internic.net
for detailed information.
   Domain Name: CJKVBBS.NET
   Registrar: XIN NET TECHNOLOGY CORPORATION
   Whois Server: whois.paycenter.com.cn
   Referral URL: http://www.xinnet.com
   Name Server: DNS3.XINNET.COM
   Name Server: DNS4.XINNET.COM
   Status: clientDeleteProhibited
   Status: clientTransferProhibited
   Status: clientUpdateProhibited
   Updated Date: 16-jun-2007
   Creation Date: 02-jun-2006
   Expiration Date: 02-jun-2008
>>> Last update of whois database: Sat, 16 Jun 2007 12:34:05 UTC <<<
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar.  Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability.  VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
reserves the right to modify these terms at any time.
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
[whois.paycenter.com.cn]
The Data in Paycenter's WHOIS database is provided by Paycenter
for information purposes, and to assist persons in obtaining
information about or related to a domain name registration
record.
Paycenter does not guarantee its accuracy.  By submitting
a WHOIS query, you agree that you will use this Data only
for lawful purposes and that, under no circumstances will
you use this Data to:
of mass unsolicited, commercial advertising or solicitations
via e-mail (spam); or
(2) enable high volume, automated, electronic processes that
apply to Paycenter or its systems.
Paycenter reserves the right to modify these terms at any time.
By submitting this query, you agree to abide by this policy.
Domain Name:cjkvbbs.net
Registrant:
Sinoshere BBS
        No.6 Avenue Kabuki chou
        420000
        Korea
Administrative Contact:
HanHeHanYue
        Sinoshere BBS
        Changan Sichuan 420000
        CN
        tel: 86 2727 757575786876
        fax: 86 7867 767868767868
        cjkvbbs@163.com
Technical Contact:
HanHeHanYue
        Sinoshere BBS
        Kyoto Beijing 520000
        JP
        cjkvbbs@163.com
Billing Contact:
HanHeHanYue
        Sinoshere BBS
        No.7 Avenue Kabuki chou
        Hanoi Sichuan 420000
        VN
        cjkvbbs@163.com
Registration Date: 2006-06-02
       Update Date: 2006-06-02
   Expiration Date: 2007-06-02
    Primary DNS:  ns2.xinnetdns.com                210.51.170.48
  Secondary DNS:  ns2.xinnet.cn                210.51.170.67
[HiChina Format]
Domain Name ..................... cjkvbbs.net
Registrant Organization ......... Sinoshere BBS
Registrant Address .............. No.6 Avenue Kabuki chou
                                  420000
                                  Korea
Registrant Country Code ......... Korea
Administrative Name ............. HanHeHanYue
Administrative Organization ..... Sinoshere BBS
Administrative Address .......... No.6 Avenue Kabuki chou
                                  CN
Administrative City ............. Changan
Administrative Province/State ... Sichuan
Administrative Postal Code ...... 420000
Administrative Country Code ..... CN
Administrative Phone Number ..... 86 2727 757575786876
Administrative Fax .............. 86 7867 767868767868
Administrative Email ............ cjkvbbs@163.com
Billing Name .................... HanHeHanYue
Billing Organization ............ Sinoshere BBS
Billing Address ................. No.7 Avenue Kabuki chou
                                  VN
Billing City .................... Hanoi
Billing Province/State .......... Sichuan
Billing Postal Code ............. 420000
Billing Country Code ............ VN
Billing Phone Number ............ 86 2727 757575786876
Billing Fax ..................... 86 7867 767868767868
Billing Email ................... cjkvbbs@163.com
Technical Name .................. HanHeHanYue
Technical Organization .......... Sinoshere BBS
Technical Address ...............
                                  JP
Technical City .................. Kyoto
Technical Province/State ........ Beijing
Technical Postal Code ........... 520000
Technical Country Code .......... JP
Technical Phone Number .......... 86 2727 757575786876
Technical Fax ................... 86 7867 767868767868
Technical Email ................. cjkvbbs@163.com
Expiration Date ................. 2007-06-02
那个域名貌似被某个无聊的人注册掉了
 楼主| 发表于 2007-6-16 22:43:20 | 显示全部楼层
《东亚文化论坛》类似的网名有很多,《汉字文化圈》就好多了。
发表于 2007-6-17 13:01:45 | 显示全部楼层
好像是鹅溪君删的
 楼主| 发表于 2007-6-17 17:13:56 | 显示全部楼层
鹅溪君是个僵尸!尸体都冷了很久了。
发表于 2007-6-17 17:25:45 | 显示全部楼层
他是王八蛋,根本就没死
 楼主| 发表于 2007-6-17 18:41:18 | 显示全部楼层
鹅溪君是上海交通大学苏州分校的在校生
网    名│网  称│姓  名│生年│职  业│位   置│信仰
凌嵐軒郁綦君│版主郎中│程思明 │1989│学生  │中国 湖北│和教
GMT+8, 2026-10-20 08:05 , Processed in 0.025302 second(s), 16 queries .
