查看: 1648|回复: 4
【分享】拉丁国际语(Latino sine Flexione)
发表于 2006-6-16 15:16:34 | 显示全部楼层 |阅读模式
拉丁国际语(Latino sine Flexione)是一个人造语言,於1903年由一位義大利數學
家Giuseppe Peano所發明,是一種簡化的拉丁語。
发表于 2006-6-17 19:33:01 | 显示全部楼层
無屈折拉丁語與國際語雖有繼承關係,但非為一物.
前者為早,已消亡
发表于 2006-6-17 19:43:22 | 显示全部楼层
http://www.langmaker.com/db/Latino_Sine_Flexione
Latino Sine Flexione
From Langmaker
Conlang Latino Sine Flexione
Author Giuseppe Peano
Year Began 1903
Language Type international auxiliary language
Lexicon Size N/A
Etymologies No
Grammar Yes
Sample Texts Yes
Primer Yes
Latino Sine Flexione is an international language and was created by Giuseppe Peano in 1903. It is written with a unique script.
[edit]Uniqueness
Peano felt that - while the Latin vocabulary is known to many people through its descendant languages and scientific borrowings - its inflexional system and syntax were too complex. By stripping Latin of its "ponderous burden of inflexions", Peano hoped to design the ideal auxiliary language. Latino Sine Flexione's vocabulary consists of all Latin words (including Latin borrowings of Greek terms) and the growing collection of common "international" words. Peano originally called the language Latino sine Flexione ("Latin without inflections") then changed the name to Interlingua. Since the IALA's Interlingua is now more well known, Peano's language is usually referred to by its original name.
发表于 2006-6-17 19:48:18 | 显示全部楼层
Latino sine flexione, le Interlingua de Peano:
un lingua ponte
(English here)
Walter A. Carnielli *
http://www.cle.unicamp.br/prof/carnielli/
“Io pensa que il poterea ducer a resultatos fructifere si alicun de iste logicos, qui trova satisfaction e placer in disveloppar sistemas symbolic, imitarea le exemplo de Leibniz, Descartes, Peano e Couturat, e dirigerea lor pensamento al problema de projectar un lingua international.”
Rudolf Carnap, in “Carnap’s Intellectual Autobiography”,
The Library of Living Philosophers, Inc. 1963 (ed. P. A. Shilpp
In 1903 le logico e mathematico Giuseppe Peano (1858 - 1932), professor al Universitate de Turin, ubi ille inseniava usque su morte al etate de 73, publicava in le jornal que ille redactava, Revue de Mathématiques, tomo 8, no. 3, octobre 1903, pp. 74-83, il suo “De Latino Sine Flexione”, o Interlingua. Ab ideas de Leibniz e Descartes, Peano diceva que, ben que il latino classic gaudeva de uso international usque al fin del 18ve seculo, Il latino es un lingua troppo difficile; totevia, fortunatemente, un parte solo del lingua suffice pro exprimer non importa qual idea.
Le latino exprime le casos grammatic de substantivos con postpositiones o desinentias (terminationes) e anque con de, ad, ex, e altere prepositiones. Le secunde methodo suffice, como in le latino popular e le linguas romance. Peano suggere dunque le abandono de le flexiones del substantivo, e le uso de prepositiones e fide al ordine de parolas. Le regulas que Peano suggere pro establir le forma invariabile del substantivo resulta, generalmente, in o le caso nominative o le caso ablative del latino. Ille suggere le mesmo pro pronomines.
Sequente su proprie suggestion ab iste puncto, Peano abandona le flexiones de caso grammatic. Anque, sin perdita de signification, on pote abandonar le generes grammatic (masculin, feminin, e neutre); on los conserva solo in alicun pronomines. In general on non distingue inter le numeros singular e plural; sed quando necessari, on pote scriber explicitemente “un “, “plure “, etc. Pois Peano remove le flexiones del verbo secundo persona, tempore, e modo. Si le contexto non suffice pro indicar le passato o futuro, on emplea adverbios.
Peano non aboli inequivocamente le participios presentate, passate, e futur e le gerundio del verbo, ma il demonstra que on pote evitar los (e anque le desinentia del passivo) per prepositiones relative.
Le vocabulario de Latino sine Flexione contine non solo le parolas classic in forma standardisate ma anque le vocabulario scientific international (metro, dyne) e cata parola que se trova in duo del linguas neolatin. Pro le pronunciation, Peano prefereva retener illo del latino classic. Comenta Alexander Gode , in “Interlingua -Latino Moderne” que “Al culmine del disveloppamento de latino occidental, illo esseva un idioma uniforme in que innumerabile nativos de Francia, Italia, Espania, Anglaterra, Germania, Polonia, Bohemia viveva e ageva 24 horas omne die. Hodie illes vive e age in francese, italiano, espaniol, anglese . .., e si nos ha signalate que omne iste linguas es plus o minus structurate in le imagine de latino, il non seque que illos non es linguas estranie le unes ab le punctos de vista del alteres.”
In 1924 le "International Auxiliary Language Association", IALA (Association pro le Lingua Auxiliar International) esseva constituite legalmente in le Statos Unite como organisation sine scopo lucrative. Peano anunciaba, in 1924, le establimento de IALA in Circulare, le jornal de su Academia pro Interlingua
Interlingua moderne nasceva in 1951 con le publication del dictionario interlingua-anglese de Alexander Gode e le grammatica preparate per A. Gode e  Hygh E. Blair con le supporto de IALA.
Duo differentias principal distingue le prime Latino Sine Flexione o Interlingua de Peano, de le Interlingua de IALA. Primo, Peano conserva un vocabulario plus archaic: on pote usar omne parola trovate in un dictionario latin. Totevia, ille admitte omne parolas moderne international e anque—presumibilemente como formas parallel—omne parolas occurrente in al minus duo del linguas romance.
Secundo, Peano suggeriva le abolition del grammatica, ben que le interlingua de IALA conserva le genere e le casos (genitive e dative/accusative in su pronomines personal); le plural de substantivos e pronomines (personal); le articulos definite e indefinite; e le tempore del verbo, le forma del infinitivo, e le modo conditional.
In 1912 Peano voleva presentar un discurso in Latino sine Flexione al Quinte Congresso International de Mathematicos in Cambridge (Anglaterra). Le regulationes permitteva discursos solo in anglese, francese, germano e italiano. Ille affirmava alora que su Latino sine Flexione esseva le italiano; ma iste tactica non succedeva, e ille debeva parlar in ver italiano. Totevia, al congresso de Mathematicos in Toronto (Canada) in 1924, on le permitteva pronunciar su conferentia in Latino sine Flexione.
      In le III Congresso Internazionale super Paraconsistentia (III World Congress on Paraconsistency) Peano poterea parlar in su Interlingua.
* Iste articulo ha essite liberamente compilate ab le ligamines Internet
Ligamines:
Union Mundial pro Interlingua
http://www.interlingua.com
Organisationes national
American Society for Interlingua
Societate American pro Interlingua
http://www.interlingua.us/
Dansk Interlingua Union
Union Danese pro Interlingua
http://www.interlingua.dk/
Interlingua–Argentina
http://www.interlang.com.ar/
Interlingua–Helvetia
http://www.castellina.org/interlingua/
Interlingua–Nederland
http://www.interlingua-nl.com/
Norsk Interlingua Union
Union Norvegian pro Interlingua
http://www.interlingua.no/
Uni
 楼主| 发表于 2006-6-21 23:17:48 | 显示全部楼层
xiexie
GMT+8, 2026-10-20 02:14 , Processed in 0.033817 second(s), 16 queries .
